Can LabVIEW load .ejs file?
RT, I want to use LabVIEW to call .ejs file, and perform script embeded in the file. it is possible?
well appreciated your suggestion here!
"I think therefore I am"
Message 1 of 8
(4,699 Views)
Since an Embedded JavaScript file appears to be a text file, you can certainly read it with LabVIEW.  What you want to do with the JavaScript, I don't know ...
Bob Schor
Message 2 of 8
(4,688 Views)
Check the .ejs file in 7z format, to see if you can open with LabVIEW.
Message 3 of 8
(4,686 Views)
I'm clearly wrong about the .ejs format (which I'd not actually seen until I examined your sample, thanks for attaching it).  I did look up the format on the Web, and thought I read that it was a text file, but clearly that was a mistake, and I apologize.
Bob Schor
Message 4 of 8
(4,634 Views)
Hi ELI,
how would you handle "ejs" files without LabVIEW?
You can use the SystemExec function to call any interpreter for ejs files you have…
Message 5 of 8
(4,630 Views)
Hi GerdW,
Currently I have to use the third-party tool to load this .ejs file, but actually I want to execute the script with LabVIEW directly.
Eli
Message 6 of 8
(4,619 Views)
Hi Eli,
Then you need to know the file format of those EJS files. And you need to know the byte code used for those EJS scripts. And you need to implement your own byte code interpreter!
LabVIEW is a programming language, but it's not a (Express)JavaScript interpreter…
What should that EJS do? Can't you implement the same with LabVIEW?
Message 7 of 8
(4,614 Views)
Hi GerdW,
EJS is a commands cluster, it will transfer application commands to binary frame so that machine can recognize.
I am now trying to understand the protocol of this script and will using LabVIEW to implement the same.
Eli
Message 8 of 8
(4,590 Views)
