Can LabVIEW overlay a dial over an image?
I would like to overlay a dial on top of an image in LabVIEW.  It would be great if the dial could rotate about the center axis.  I included an attachment of what It would possibly look like.  Please let me know if any of you know how to do this.
Thank you!
Message 1 of 10
(3,932 Views)
You should use the Picture object for this. It has a slew of VIs to draw all kinds of things. Combined with the geometry VIs, you should be able to achieve what you want quite easily.
Message 2 of 10
(3,921 Views)
Accepted by topic author R0B0T
This tutorial might help you: https://decibel.ni.com/content/docs/DOC-4819
Message 3 of 10
(3,915 Views)
You need to set the other items on a normal dial to transparent and place it on top the image.
Omar
Message 4 of 10
(3,914 Views)
THANK YOU!!! Smiley Very Happy
Message 5 of 10
(3,873 Views)
Would you be able to save down to LV 9?
Message 6 of 10
(3,872 Views)
Message 7 of 10
(3,869 Views)
Omar, you rock.  thanks!  Smiley Happy
@Omar II wrote:
2009
Message 8 of 10
(3,850 Views)
I apparently misinterpreted the question...
In any case, I am attaching an example of what I had in mind (LV 2011 project), for what it's worth.
Message 9 of 10
(3,814 Views)
Message 10 of 10
(3,808 Views)
