Can LabView access Windows NT's account database?
Can Labview access Windows NT's account database to use for security within the Labview application?
(2,709 Views)
If the user executing the program can access it, i think it can be done using WinNT api calls, check http://msdn.microsoft.com/library/psdk/psdkref/catfunc_26m1.htm for different api calls that you can make.
Hope this helps
(2,709 Views)
