Can LabView compare two curves?
Now I'm making software to compare two curves are similar
or not. Those curves can be shifted a bit but I want to see
if these "shapes" are identical.
Does LabView have capability to see similarity for two curves
or any theory around here?
Dan,
Hiroshi Shimase (Oji Paper + Howe Sound Pulp & Paper)
TEL : 604-886-3579(home) 604-884-2491(office)
Home : hiroshi_shimase@dccnet.com or hiroshi_shimase@mac.com
Office: hshimase@mail.canfor.ca
WEB : http://www.geocities.co.jp/SiliconValley-PaloAlto/4268/
(4,053 Views)
You can calculate the cross-correlation function between the two curves
to estimate
their "similarity". Labview has (in the Advanced Analysis Library) two
VIs that should do
the job:
- in the function menu 'Signal Processing-->Frequency Domain-->Cross
Power.vi' computes
the cross-correlation power spectrum
- in the menu 'Signal Processing-->Mesaurements-->Cross Power
Spectrum.vi', which computes
Magnitude and Phase of the cross power spectrum
Both require that the signals X(t) and Y(t) are sampled at equal
t-values.
If you don't have the Advanced Analysis Library, try to get it
-Franz
Hiroshi Shimase schrieb:
> Hi,
> if these "sh
> Dan,
(4,053 Views)
