Can LabView pull up a PowerPoint slide?
(2,762 Views)
Hi Jsimms,
This was all the information I could find for you, you did not give me much to narrow down the search field for what you wanted exactly.
Extract comments from PPT or Is it possible to control a MS powerpoint slideshow using labview? finally Is it possible to control a MS powerpoint slideshow using labview? another post
Hope this helps you.
Regards
JamesC
NIUK and Ireland
(2,752 Views)
