Can Labview 7.0 be used with Microsoft .net 2.0 references?
I'm using Labview 7.0. I would like to know if I can use references (dlls) that were built on Microsoft Framework 2.0
Message 1 of 8
(3,204 Views)
Hi hdicko,
Check out this post.
Best Regards,
Jonathan N.
Message 2 of 8
(3,195 Views)
Look at that post, but be sure to look deeper (follow the link to Brian's blog and read the comments). You should also go over everything Brian posted that if you are planning on using .NET with LV a lot. Be aware of the fact that 7.0 was the first version which supported .NET and might have some bugs\missing features.
Short answer: Yes, LV 7.0 does work with .NET 2.0 and I use it regularly.
___________________
Try to take over the world!
Message 3 of 8
(3,178 Views)
Is the patch LabView 7.1.1 free? If so then were can I get it?
Message 4 of 8
(3,173 Views)
The second link there did point to the patch, but that patch is only for 7.1.
7.0 works fine with .NET 2.0 without any patches.
___________________
Message 5 of 8
(3,169 Views)
Thanks MooooView. I didn't read your first reply carefully. I'll test it today and post the response.
Message 6 of 8
(3,163 Views)
Another question then? Does Microsoft. net 2.0 work with Labview 7.1?
Message 7 of 8
(3,154 Views)
Probably not, but 7.1.1 is a free patch to 7.1, so you can just install that. I suggest you just read Brian's blog for all the details.
Oh, and MoooooVIEW is just the signature. It was simply a joke because of the avatar used.
___________________
Message 8 of 8
(3,149 Views)
