Can Labview and VEE be used on the same computer?
Can Labview and VEE be used on the same computer? If so, how are VISA conflicts avoided?
(2,611 Views)
This is all speculation on my part. With two different LabVIEW applications trying to access a VISA resource, you can use the VISA Lock function. There's a shipping LabVIEW example called Locking.vi that shows how it's done in LabVIEW. If VEE has a similar function, you could try putting a VISA Lock and Unlock around each VISA call to common instruments.
(2,594 Views)
