Can Labview apps be ported to CVI/Labwindows?
I use Labview as an interface to my devices but I am not an expert
programmer in C/Labwindows. I would like to know if Labview-apps
("graphical" code) can be migrated to C/C++ code on a Labwindows
environment.
Can I implement and "export" a subVI to Labwindows?
(3,278 Views)
Labview 8.0 --> Labwindows 8.0
(3,276 Views)
No.
This is a frequently asked question, as a similar one was just asked.
(3,260 Views)
environment.
The only thing you can do is using the LabVIEW application builder to turn your VI(s) into a DLL and call that from LabWindows CVI. There is no way currently that LabVIEW can convert its VIs into C code for LabWindows CVI or other compilers targetting Desktop OSes. The only LabVIEW that can do something in this direction is LabVIEW Embedded Development Module but that costs lots of $$$$$ and targets 32bit embedded plattforms for embedded applications (eg. no local UI, specific LabVIEW embedded environment and interface libraries, and a few other not so trivial details).
Rolf Kalbermatter
Message Edited by rolfk on 11-22-2006 10:47 AM
Rolf Kalbermatter  My Blog
(3,250 Views)
