Can Labview drivers be on a different drive then the C?
I want to put the drivers on a different drive is this possible?  Thanks
(2,439 Views)
@justified wrote:
is this possible?
Possible, probably yes - just point the installation to another drive.
Desirable, I would guess not, because things work best in their default location.
However, if you want to install everything (including LabVIEW itself) to a different drive, you should probably not have any problems.
___________________
Try to take over the world!
(2,427 Views)
