Can Labview make executable file?
Can Labview make excutable file that could run indepedent on Labview? I
am using academic version Labview 5.1. VI can't run without Labview. I
am wandering if the enterprise version of Labview had the feature or
not.
thanks.
G. Chen
Ph.D. Candidate
Ohio Univeristy, Athens, OH
Nothing can dim the light which shines from within.
Sent via Deja.com http://www.deja.com/
Before you buy.
(5,729 Views)
absolutely, its an add-on package called the "Aplication Builder"
G. Chen wrote in message <836bcg$mbp$1@nnrp1.deja.com>...
>Hi,
>not.
>thanks.
>G. Chen
>Ph.D. Candidate
>Before you buy.
(5,729 Views)
You have to have purchased the application builder option. I don't know
if it was available prior to version 5.0. Version 5.1's application
builder works well and generates smaller .exe files than 5.0
G. Chen wrote:
> Hi,
> not.
> thanks.
> G. Chen
> Ph.D. Candidate
> Before you buy.
(5,729 Views)
