Can Labview v7.1 build applications for Win. 98?
I recently upgraded my labview version to 7.1, but since it can't be run on Windows 98 I had to install my copy of labview on an XP machine that is not attached to the hardware I want to control (The hardware is only compatible with Win. 98). I was thinking that maybe Application Builder would be able to bridge this gap by allowing me to build executables that I could then run on my windows 98 machine, but it appears that this may not be possible as the applications that are built state that they too can only be executed on 2000/NT/XP machines. Is there any way to build applications that can be run on 98, or is there any other way to solve this conundrum?
Thank you for any help you can give.
-Danny
(2,808 Views)
Hi Danny42,
a similar question was already discussed here.
Hope it helps
Indiana
(2,803 Views)
Thank you for your help Indiana.
-Danny
(2,794 Views)
