Can LavVIEW call a dll and return a handle?
I wanted to design a LabVIEW in the way of dll calling. I used the
"Video for Windows" in Visual Studio 2003 .NET and created a dll file
with a function calling of capCreateCaptureWindow(). This function
returned a handle. But when I used the Call Library Function Node, I
found handle wasn't a supported type.
Are there any ways to return a handle to LabVIEW?
Thank you!
(3,069 Views)
Hi, Andrew,
In your case you can use I32 type for output handle to the parent window.
best regards,
Andrey.
(3,064 Views)
Hi Andrew
Andrey is right.
For more information, please refer to this Help Document (Using External Code in LabVIEW)
Bottom of page 44/312 (pdf) talks about treating Handles as U32's
Hope this helps
Van L
NI Applications Engineer
(3,034 Views)
On Mar 6, 4:10 pm, Andrey Dmitriev <x...@no.email> wrote:
> Hi, Andrew,
> &nbsp;
> &nbsp;
> best regards,
> Andrey.
An I32 type is OK? I thought handle was a pointer therefore I should
try another way...
Thank you very much! I'll try right now.
best regards,
Andrew
(3,018 Views)
Will "Adapt to type" suffice or not? Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,013 Views)
No, it seems to be not pointer:
http://msdn2.microsoft.com/en-us/library/ms707166(VS.85).aspx
Return Values
Returns a handle of the capture window if successful or NULL otherwise.
But you can also prepare your own simple DLL-Wrapper if you have troubles with passing parameters from original functions to and from LabVIEW.
Andrey.
(3,003 Views)
