Can Microsoft Powerpoint open a VI ?!
Hello NI community , this is my first porst , than I spect to be clear on my question.
My problem is , there is some way to open an specific VI , RUN IT and after it's executin , CLOSE IT on a specific slide from a powerpoint file ?
I have a powerpoint presentation of DAQ automation , and when the presentation reach the specific slide (slide number 5 for example) I want to open the specific VI , execute it's functions and after that close it.
Is there any way to do something like that ?
Thank you very much.
(3,132 Views)
Okay the direct answer to your question is no.  But then a "maybe".
LabVIEW is the only thing that can open a VI.  The Run-Time engine is the only thing that can run a VI (let's assume the Run-Time Engine is part of the development environment)  So no, Powerpoint can't open a VI.
But, if you have LabVIEW installed on the machine, you can call into it with a command line call to open a VI.  If the VI is set to run when open, you can have it look like PowerPoint is running a VI.  Something I am unsure of, is if PowerPoint can run a command line program.
(3,123 Views)
Hooovahh wrote: Something I am unsure of, is if PowerPoint can run a command line program.
I haven't done it, but I'm pretty sure you can have a hyperlink to a file and then Windows will try to open the file in whatever the default program for that file type is.
(3,106 Views)
Piling on here - http://office.microsoft.com/en-us/powerpoint-help/start-a-program-during-your-presentation-HA0101997...
Jim
(3,103 Views)
I wrote a slideshow program using LabVIEW. SInce LV is already "running the show," so to speak, demonstrating a VI is trivial. The code is not in a condition to share.
Lynn
(3,049 Views)
