Can NI 9474 or NI 9237 be used to control motor pumps
I am using cDAQ-9172 as the data aquisition system and I am planning to control a motor pump to run fluids, can modules NI 9474 or NI 9237 be used to control the pump?  I know that NI 9505 which is a full H-bridge brushed DC Servo Drive Module which can be used to control pumps is not compatible with the cDAQ system.  I am very new to this, please help me with it.
(2,816 Views)
I think some more information about your motor is needed, specific information about what types of control signals it requires along with what voltage it needs as well as current draw/ device name/model number would be helpful.  The NI 9474 can supply 5-30V with a 1A max per channel as can be found in the product manual. Please post back with your motor specs and we will be much better equipped to help.
JaceD
Signal Sources Product Support Engineer
(2,798 Views)
