Can PCI 6519 IO card support waveform(digital) output ??
It is quite hard to find out in the spec.
NI group all the series of DAQ board in the spec.
Can anyone tell me if it can support waveform output .
The waveform is about 1Khz
thx very much.
(2,583 Views)
The PCI-6519 does not support hardware-timed digital I/O. You can update the digital output one sample at a time in software, so you are limited by the speed of the computer you are using as to how fast the updates can be.
Michael P
(2,569 Views)
