Can PXI-8531 be a slave node to communicate with Park's IQAN-MD4?
I am wondering if it is possible to configure a PXI-8531 as a salve node using LabVIEW?
I read that CANopen library only supports to configure the module as a master node.
PXI-8531 is a CANopen module. Is there any other way to make the PXI-8531 to be a slave node in the network?
It seems like IQAN-MD4 needs to be the master node...
If anyone has experience on connecting a IQAN-MD4 and a PXI and would like to suggest a better idea on this, it would be very helpful.
Thanks a lots.
(2,410 Views)
Hi EpicJean,
It does seem like the PXI-8531 does support slave node configuration, however I can't seem to find any examples of how to do so.
NI PXI-8531 CANopen
https://www.ni.com/en-us/shop/model/pxi-8531.html
Applications Engineering
(2,368 Views)
