Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can Run-Time Engine 6.0 runs on Window XP?
ATC
Member
03-18-2002
04:53 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a 6i LabView application and I did build Run-Time Engine 6.0 for that! My boss asked me that if our customer has Window XP and does not have LabView 6i whatsoever, with Run-Time Engine 6.0 install, will have any problem?
0
Kudos
Message
1
of 2
(2,701 Views)
Reply
Re: Can Run-Time Engine 6.0 runs on Window XP?
Lab Viewer
Active Participant
03-18-2002
11:09 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
As this
Compatibility
article states, you won't have to worry about.
Good Luck
0
Kudos
Message
2
of 2
(2,701 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
