Can VS WinForms toolbox add an dll/ocx with UI element (dll/ocx generate by the labview)
As I know , LabVIEW can generate the dll(.net interop dll), that dll can be references in VS .net projects.
When some one design function in the LabVIEW with UI element, does the function with UI element can be generate into .NET component (add in vs toolbox)? or generate as ocx control?
Message 1 of 1
(1,226 Views)
