Can a color box control be changed so that only 4 colors may be selected.
I wanted a color box to be used as a control so that when the user left clicks it, there are 4 colors that they can select which will dictate what the program will do.  Currently, left clicking on the color box brings up a variety of colors, and the only ones that I can control are the "User" colors, which I have modified to only show the four colors I want.
However, the remaining color sliders and History colors etc are still displayed.  Is there a way so that only the four "User" colors can be displayed when clicking on the color box?
Thank you.
(2,771 Views)
Accepted by topic author M. Bobby
Hi Bobby,
I would suggest using a picture ring instead. Here you can display just 4 (differently) colored rectangles to the user...
(2,770 Views)
I have made one of these before here it is hope it helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,754 Views)
Thank you very much, the picture ring worked very well.
Harold unfortunately I don't have 8.6 and so couldn't view your file, but I think I have it figured out.  Thank you very much for your reply.
Message Edited by M. Bobby on 06-24-2009 03:00 PM
(2,747 Views)
