You can also use the method Ben mentioned just by having the subVI reentrant, which has some advantages. Just be sure to set the flags on the Open VI Reference function to prepare for reentrant execution (8 or 2, I can't remember). You can then use the reference to work on a specific instance.
___________________
Try to take over the world!
