Can a portable type definition be made?
A Question for the elders
I have made myself a nice code template VI that I wish to re-use easily. The snag is it references a type definition in a subfolder of user.lib
so when I try to RE-use my creation I encounter the dependencies of that type definition.  (Sound familiar?)
I tried a few different things to solve this problem but got nowhere. I've never been able to figure this out on my own.
So my Q is there perhaps a procedure for doing this?
What I am looking for is a way to write this template so that I can drop it on a block diagram then rename the type definition that supports it without screwing up the original code template
buried somewhere in user.lib
All I could think of was to disconnect the type definition and manage it manually.
(2,824 Views)
Accepted by topic author AKA_TG
As you know there is such a thing as a template VI (*.vit). But there is also a template control (*.ctt). Create a template VI (with the extension *.vit) and install on its front panel a typedef control (with the extension *.ctt). When you open this template you will get a clone of it that has a clone of the control on its front panel.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,789 Views)
Thank you mikeporter!
Im excited to try that out!
(2,777 Views)
Yay!
It actually works!
I will say this however ...
It was definately not easy to figure out the proper steps.
But once that was put aside I did manage make several of my personal favorite templates (that use typedefs) portable and that is worth a lot!
 Great tip Mike!
(2,752 Views)
