Can a vi tell if it was called or just run?
Can a vi tell if it was called (perhaps through the use of something akin to
the property node) or else is running as a top-level vi?
Note that this would have to work even in the presence of memory-resident
callers of the vi that were not running (this precludes the use of the
property node "callers" data item).
I'd also like to rule out additional front panel controlls that are only set
by callers.
TIA,
Warren Massey
Massey4@LLNL.Gov
(3,354 Views)
Found it myself after some more looking. It is indeed a property node item
under Execution - State.
"Warren Massey" wrote in message
news:38cd5c40@newsgroups.ni.com...
to
set
> by callers.
> TIA,
> Warren Massey
> Massey4@LLNL.Gov
(3,354 Views)
> by callers.
> TIA,
> Warren Massey
> Massey4@LLNL.Gov
Check out the property node with the property "State"
This returns the following:
"Bad"
"Idle" - in mem but not running
"Run Top Level" - Running as the Active Top Level VI
"Running" - This seems to say that a Top Level has reserved it
to "possibly" be run. Not that it actually
IS running.
Kevin Kent
(3,354 Views)
Warren Massey wrote in message
to
As well as using property nodes, you can also use the "call chain" function;
this simply returns an array of VI names from the vi back up to the top
level. If the array has a size of 1, then you are the top level.
(3,354 Views)
