Can any one help with VI for getting data(HEX) from serial and write in text file
Ali,
Please don't mark your reply where you thank Mike as the solution.  Mark Mike's actual reply as the solution.  You can go into the options of your message to unmark yours as the solution.
Message 11 of 12
(579 Views)
Your max and min function is set up such that you will only read 0 or 1 bytes from the port at a time, is that the correct behavior?  If you can read chunks at least the size of the termination string you are looking for, you can use any search string function to check if any matches were found and terminate your loop if there are.
Jeremy_B
Message 12 of 12
(540 Views)
