Can anybody convert these 8.5 SDK files to 7.1?
http://www.clevemed.com/support/SDK.shtml
I need the Labview files from that SDK but they are all 8.5 and my development team only has 7.1 currently available.
If there is a better way or some type of compatibility plugin I could use I would prefer that
There are several files in the SDK. I can upload them here isntead of just linking to them if that would be preferable.
(2,438 Views)
Accepted by topic author BCharlton44
In the future please post in the Downconvert Requests Thread
Link is provided on the front page of the forums in the Announcements section.
Attached is the code in 7.1. Two subVIs were not in the package, so you'll need to use the stock Read/Write from Spreadsheet File VIs. Looks like whatever they had were wrappers around the standard VIs with added error handling clusters as I/O.
(2,431 Views)
