Can anybody please convert 8.0 to 7.1
I guess I was successful in downconverting 8.6 to 8.0. Now I want the same program to be available in 7.1. Some of the sub vis seem to be missing while you open it without the required dll . Still it would be thankful.
(2,814 Views)
Accepted by topic author malavi
There are a LOT of subVIs missing, so I don't really know how much help this VI will be to you. It also appears to be unfinished code, based on the comments within the code. Also, there is some questionable programming in it, so beware.
(2,794 Views)
KUDOS.  Thank you .It worked.
(2,786 Views)
