Can anyone check out where exactly I am going wrong
I am doing this task using sbRIO9642 and sound and vibration signal simulator box  (in search of manual) on FPGA
using "TACH OUT " signal from the box so measure the speed  to the on board ports of sbrio
I am trying to measure the speed of the fan and here is the code for this
everytime when i run this code
RPM is starting from zero but I want the final value to be displaying....
So that I can use this as a process variable to control the speed of the fan using pid
(2,982 Views)
Accepted by topic author irfan789
What if you would leave the shift register uninitialized?
(2,970 Views)
As Altenbach is implying, since you initialize the shift register it'll start from 0 every time. To start from the last achieved value, use an uninitialized register.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,952 Views)
ya got that and error rectified
thanks a lot...
(2,935 Views)
