Can applications made in Labview 8.2 be run on a windows 7 machine by installing the runtime engine V8.2
Can labview executables made in V8.2 be run on computers using Windows 7?
if so which runtime engine should be installed on the windows 7 computer?  V8.2
regards
jqm
(3,862 Views)
I have tried only once which had run time compatible to XP, and I didnt have or notice any problem . I would say try downloading and install 8.2 runtime which is XP, VISTA and WINDOWS 7 compatible.
(3,859 Views)
Where do you see that 8.2 is compatible with Windows 7 or Vista?
(3,854 Views)
I'm sorry, didnt do background check, I have 8.2.1 and 8.6, there is no version of 8.2 which is compatible with Windows 7, latest is 8.2.1 which is compatible with Vista machines.
(3,850 Views)
This question has been asked before MANY times. Did you try a search?
Some people (such as myself) have been able to get it to install by running the setup program as Administrator. Your mileage may vary.
(3,834 Views)
