Can i build Applications for android using Labview
Hi Everyone,
                I want to build simple apps on Android operating system usng labview can i do it? I have seen data dash board but i want to program for other than measurements.
Vishwas
Message 1 of 8
(10,567 Views)
No you can't. Data Dashboard is the closest thing you can get so far!
Rolf Kalbermatter  My Blog
Message 2 of 8
(10,552 Views)
Hi rolfk,
           Thanks For your reply and i want to know if NI is planning on somethig like this in future.
Vishwas
Message 3 of 8
(10,495 Views)
There is a related idea in the ideas exchange, you can vote for it. There is no announcement by NI that someting like this is even planned.
The mentioned data dashboard will apparently receive significant enhancements in spring 2014 (v 2.2, details here [link removed; article no longer available])
Message 4 of 8
(10,490 Views)
NI actually showed an early protootype of a LabVIEW like application for iOS devices two or three years ago at NI week. They were experimenting about how to do editing operations on touch screen devices, as the current paradigma in LabVIEW is very mouse oriented and completely unsuitable for a touch screen operation. It looked nice but didn't do much more than have a few arithmetic nodes and simple front panel objects. NI never said they were planning to release a product like that and mentioned repeatedly that there were still a lot of problems to tackle in areas like user interaction and hardware constraints of the target platform before this was a feasable product. After all NI is maybe best known for LabVIEW nowadays but their business is still largely driven by hardware sales and most iOS devices have very few possibilities to extend them with measurement hardware and Apples restrictive policies about third party add-on manufacturers doesn't help that in any way.
Message 5 of 8
(10,401 Views)
Well, the original post was about Android, not iOS. No restrictions regarding 3rd party software there.
Message 6 of 8
(10,375 Views)
Considering the current state of affairs between iOS and Android it is a safe bet that IF NI decides to release a software like LabVIEW for iOS there will be a similar version for Android. Anything else makes little sense nowadays, since Android clearly has a dominant market share in more than 3 quarter of the countries around the world. However as I have pointed out, there are many hurdles to take for NI to release a tablet/smart phone version of LabVIEW, some technical and others marketing wise.
Personally I would love to have the possibility to just add an Android target to any LabVIEW project and generate directly a GUI for my control application hosted on a cRIO. However commercially that ability while being nice wouldn't make a big difference for me at this point.
Also the hardware extensibility still is limited even for Android devices. Most Android devices still would be limited to UI applications only as there is no easy way to plugin a PCI board. 🙂 Even integrated connectivity to cRIO is not likely going to happen since the NI-RIO interface layer is quite a beast and very unlikely to be ported to other platforms than what is currently available.
Message 7 of 8
(10,348 Views)
A bit late to the party, but I figured out a way to do it using Cordova and WebVIs.
Have a look at my manual:
https://forums.ni.com/t5/Example-Code/Native-Android-and-IOS-applications-with-LabVIEW-web-modules/t...
I also have a small presentation on YouTube that describes the thought process:
https://www.youtube.com/watch?v=KvEAUReBjeM&t=2553s&ab_channel=VITechnologies
Hope it helps!
Br,
Natan Biesmans
#Edit: Also works in G web development software.
Message 8 of 8
(6,177 Views)
