Can i change voltage range on input of FPGA
Hi
I would like to change the voltage range that I read on my FPGA from -10-10V to something closer to -2.5 to 2.5. Is this possible?
(2,520 Views)
Accepted by zepp2
Hi zepp2,
Could you clarify which hardware you're using?
If you're using an R series device, the input is fixed at ±10 V.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,501 Views)
