Can i connect a bundle to a .net struct
I would like to know, if it is possible to connect a bundle  to a .NET struct.
I have a method that receives a struct with two strings.
On the attachment is an image with a small example, in reality i would like to connect a bundle with (string, int, boolean)  to the method ST
(2,654 Views)
Have a look on the following link which explain communication between Labview and .NET:
http://zone.ni.com/devzone/conceptd.nsf/webmain/307935CAE96229EC86256D3600716325
Regards.
Omar S. NI
(2,633 Views)
There is no automatic mapping between a LV cluster and a .NET structure. You'll need to unbundle the cluster and set each property/field of the structure one at a time. Of course, in the example you posted, there isn't a need to create the cluster in the first place, but if you do accept the cluster as an input parameter to a VI, you'll need to unbundle it.
Basically, if your invoke node or property node show a LV data type, then you can wire a LV native type in. If it's that thin, green refnum wire, that means you'll need to use the property or invoke nodes on it to set or get any data.
(2,627 Views)
