Can i get a reference to an element that is in an array of clusters?
Hello Folks,
I have an array of clusters. Inside (each) cluster is a Menu Ring. Is there a way to get a reference to a specific menu ring (ie the ring from a particulat element in the array)?
My real goal is to grab the text from the ring. When i unbundle a cluster i just get the number, not the text.
For the moment i kludged it so that i grab the list of strings as an array and use the numerical data from the unbundle to select the proper string, but this seems sloppy.
Thanks for any help,
eric
(2,618 Views)
hook your array to for loop. Inside unbundle clusted and create an indicator. The use property node to read the strings.
hope it helps.
Pawel
(2,618 Views)
