Can i make an automatic Print screen in labview ?????
HI all
I need to make a loop that have an event with a function, that takes a screen shot and save it to a file in JPG.
By that I thought if  Labview has a function that can control the 'Print Scrn' butoon on the Keyboard! But automatic. Meaby it's easier!
I've search all the labview functions specially in application control, but find nothing that could control the Print screen.
Is it possible..?
Regards
Zamzam
HFZ
Message 1 of 45
(8,449 Views)
Hi Zamzam,
use a 'invoke node' with method 'get panel image' and with a reference to the vi, then use standard picture file functions to save the resulting picture...
Message 2 of 45
(8,442 Views)
I love Labview!!!
Thanks!
HFZ
Message 3 of 45
(8,437 Views)
I love Labview!!!
Thanks!
HFZ
Message 4 of 45
(8,437 Views)
Hi Zamzam,
I have the same problem as you... Would it be possible for you to send me an example on how to make a screen shot every second for instance?
Thanks a lot,
Marc
Message 5 of 45
(8,219 Views)
Hi Marc,
try this.
Mike
Message 6 of 45
(8,200 Views)
Hi Mike,
Thanks a lot for your answer. My question was kind of wrong...because what I really want to do is to take a screen shot of all of the screen( not just the front pannel like I said before). Would anybody know how I could modify the VI I have attached (it only takes a screen shot of the front panel) in order to screen shot all of the screen ?
Thanks a lot,
marc
Message 7 of 45
(8,194 Views)
Hi marc,
this will not be solved by just modifying the last vi. LabView has (AFAIK) no function/property node/method to get the actual windows screen, it can only control frontpanels of vis.
So you have to use some windows function calls (via "Call Library Function") and you better look into MSDN...
Message 8 of 45
(8,187 Views)
That's an OS related operation, not a LabVIEW operation. Which OS are you running? If you're on Windows you can delve around into the API, or you can try to find a screenshot utility that has an ActiveX interface.
Message 9 of 45
(8,183 Views)
Hi everyone ,
Thanks for all of your answers. I understand that I can't use my VI to make a screen shot of my screen. I am using Labview 8.5 and windows XP. Woould one of you have an example I could work around? I have no experience in this kind of communication.....
Thanks a lot again,
Marc
Message 10 of 45
(8,167 Views)
