Can i write labview data into origin?
After measuring input voltage i was trying to save the data into a file and it saves the file with "lmv" extension, this file can b opened in text or excel. I want to open the data in origin 7.5, please let me know if this is posssible n if so how?
(3,509 Views)
Excel saves only 65000 data and i nedd to same about 600000 or more data, what are the format in which i can save labview data?
(3,508 Views)
Hi Amber,
Origin supports simple spreadsheet files (aka "csv", comma separated values; also allows other spearator characters), so you may choose the standard "write to spreadsheet file".
With Origin you also get some vis that allow direct communication between both programs (similar to a device driver).
(3,487 Views)
