Hi Dennis,
Good question. The Database Connectivity Toolset requires the ADO ActiveX Objects. However, that doesn't necessarily mean you have to have Access installed on that machine. The toolset actually installs a series of components:
Database Connectivity Toolset for LabVIEW
SQL Compatability VIs for LabVIEW
MDAC (Microsoft Data Access Components)
It is in the installation of the MDAC that includes the ActiveX Data Objects software and drivers, ODBC drivers, and OLD DB drivers. So, you don't actually have to have Access installed to get the ADO Objects onto your machine. Hope this clears things up!
Jeremy L.
PS - fans --
The Database Connectivity Toolset User Manual is a good reference to keep handy as you program databases in LabVIEW. I would download or bookmark this for future references
Jeremy L.
