Can labview create 'reentrant' dll?
Can LabVIEW create re-entrant dlls; by which I mean a dll that maintains state information between calls? If so, how do you implement it?
(3,172 Views)
Accepted by topic author ToeCutter
Maintaining state information can be done by means of an uninitialised shift register.  This works in a LabVIEW DLL, too.
Make sure that the DLL doesn't get unloaded between function calls else it will loose it's memory.
(3,147 Views)
Thanks Guenter! Kudos+1.
(3,138 Views)
