Can labview do this? Project to Function pallette.
Is there an easy way for labview to automatically add the current project right to a palette in LV 8.5.   It would be very nice to have the current project hierarchy avaliable in the functions pallete.  This saver having to navigate to the project window and drag vi on the block diagram (curently my fastest method of adding project code to a new vi).  If this is not in there it is a feature which could save me time in the long run (a few seconds done hundreds of times a week really adds up).
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,813 Views)
Insofar as I know the palette will not allow you to insert a link to a project. All that you can do is insert a directory. I don't have LabVIEW 8.5, but I don't believe it contains any methods to programmatically access the palette set. I think the only thing you can do is to create multiple menus in your "User Libraries" or "Favorites" for the projects that you use.
(2,802 Views)
