Can labview simulate generating a moduleted signal? Such as GSM or CDMA.
Now I can get a GSM signal from SG, And I want to compare the signal from SG with the signal generated by Labview.
So I want to ask 'Can labview simulate generating a moduleted signal? '
(2,417 Views)
What do you mean with SG? Signal generator I assume?  Of course Labview can generate a modulated signal.  You can build it with a with a waveform.  But for what purpose?
(2,412 Views)
Thank you for your answer.
1、Yes,SG means Signal generatorSmiley LOL.
2、You said I can build a modulated signal with a waveform,Do you mean I can get the signal without connecting the hardware?
3、I want to compare the signal of Signal generator with the signal of labview.Smiley Very Happy
(2,399 Views)
1、Yes,SG means Signal generator大笑表情.
3、I want to compare the signal of Signal generator with the signal of labview.极度高兴的表情
(2,395 Views)
