Can labview solve this equation?
I need to solve this equation in labview to t. X and Y are known values.
And if this part can't be larger then 1. If it is, it should be made 1.
I have really no idea where to begin to solve this problem.
Thanks in advance!
(3,211 Views)
If I did my math right, it simplifies to abs(t) = abs(x/1000)
Randall Pursley
(3,196 Views)
If you are actually trying to solve it recursively, then Newton's Method should work.
Actually after checking it, it's obvious the that any value of t at the input will give you the correct value of t at the output.
Message Edited by rpursley8 on 11-21-2005 12:09 PM
Randall Pursley
(3,189 Views)
