06-28-2017 08:39 AM
In Win 8.1, I could pin .lvproj files to my LabVIEW taskbar icon, so when I right clicked, I could select my most important work. I have since upgraded to Win10 and now I can only pin recent VI's, and not the project itself:
Has anyone had this problem and found a solution?
06-28-2017 09:49 AM
I can't really say. I run several different versions of LabVIEW so I avoid this kind of opening at all costs. (The project/vi will open with the last version of LV that you used.) Instead, I just pin them to the LV Getting Started Window of the LV version it is associated with.
