Can not display outside the while loop when false do nothing in inside the loop
I have a array of double indicator which is display an output outside a while loop, but it did display 0 at index 0.
Inside the while loop I have false case that do nothing, only output data when it is true.
In the attachment, the numeric dispalys a correct value, but the array does not? What wrong with it?
Message 1 of 10
(4,306 Views)
Hi cguan,
well, the VI looks quite ok. I only added a constant to initialize the shift register correctly. See if this helps...
Message 2 of 10
(4,301 Views)
You do know that the array indicator will not display anything until you've hit the stop button in your VI, don't you?
Message 3 of 10
(4,297 Views)
thank you guys, I want to have a real time display, what do I replace the array outside the while loop?
Message 4 of 10
(4,289 Views)
Hi cguan,
when you really want a "realtime display" you should place the array indicator in the loop...
Message 5 of 10
(4,277 Views)
But of course, remember, you don't want to be updating faster than about 10x per second (especially if it is a LOT of fp data) as this can bog down your VI. I often times have a "update fp" state that is called every "x" number of milliseconds. I mean, does the user really need data THAT fast anyways?
Message 6 of 10
(4,268 Views)
Actually, what I really want to send the data to a calculation while loop in another sub vi. The indicator is just to prove if the data can be read outside the while loop.  Can directly send the data to another while loop?  Thanks
Message 7 of 10
(4,254 Views)
yes you can, use a notifier
Message 8 of 10
(4,249 Views)
I add a notifier in two while loop but the receiving loop's data deos not updating. It looks like the array of double index 0 desn't change.
In the attachement, the numeric 2 data showing the first value and that stay there, while the numeric keep changing.
Did I do something wrong?
Message 9 of 10
(4,231 Views)
Because you are always looking at the first (zeroth) row of your array in the consumer loop.  Don't use index array, just look at the whole array in an indicator.
Message 10 of 10
(4,224 Views)
