Can not find NI-DAQmx icon in Labview
Hello
I have installed Labview 2017 evaluation version, and, subsequently, NI-DAQmx software. However, I can not find "NI-DAQmx Data Acquisition" icons in Measurement I/O palette of Labview program. I wonder what is the problem and how may I solve it? Thank you very much!
Best regards, Xing
(3,271 Views)
What version of DAQmx did you install?  It should be 17.0.
(3,252 Views)
Thank you for your asking. My labview is 17.of1.
Do you know how to solve this issue? Thanks.
(3,245 Views)
My question was the version of DAQmx.  You already stated you had LabVIEW 2017.  If you installed anything before DAQmx 17.0, then LabVIEW 2017 will not be supported.
(3,242 Views)
Labview does not like older drivers in the computer when installing 17.0. Remove old drivers and install the 17.0 version. You have to reinstall the 17.0 Daqmx drivers, it did not install properly. That should fix it.
(3,197 Views)
