Can not find data log (Write to measurement file)
Hi ,
Can someone pls kindly help me check my oven labview.vi?
I have save data log but unable to find .tdms format or .txt file in the folder of temperature data logging.. i set with write to measure file.
i go in the path of data log but found non.
Pls kindly advise.
Thanks and Regards,
Brian
(3,276 Views)
Hi shwemy,
does your folder "C:\LV\LVL5_Shared variable Folder\Oven_Labview Project\Oven_Labview_Datalog.tdms" really exists?
Do you have write access rights in that folder?
(3,269 Views)
Hi GerdW,
Thank you so much for prompt response.
Yes.. there is folder exist. I make sure i click the folder icon and save the file. When i click run and go in to folder see the .tdms file but unable to find. I have also tried to save with .txt. also unable to find.
However if i use the sub vi.. i use the write to measure file function in sub vi.. the data log for individual able to save..
I need all data in one file format..
Thanks and Regards,
Brian
(3,261 Views)
Hi GerdW,
i used to save the location for the 2 x subvi .. i can see the .tdms data log..
But i need all data in one file format for my main vi project.
Thanks and Regards,
Brian
(3,256 Views)
Can someone pls kindly help the data logging?
(3,221 Views)
