Can not find text in Multicolumn Listbox in LabView 8.20
Problem is that if you do a Control-F to find a specific text, for a multicolumn listbox it doesn't tell where it is specifically. Only that it is located somewhere in the listbox.  It is working properly if you have embedded text in a String control/indicator, or in your diagram.
In Labview 6.1, it goes directly to your text location ( Do a Control-G), but in LabView 8.20, it doesn't go there.
I submitted a example VI, compiled in Labview 6.1.
Seems like this is a bug in Labview 8.20 for the Find Text feature (Control-F).  I would like to know if there is a workaround.  I have built a large VI that puts the text into a multicolumn listbox, and the search feature in labview is useful to know where things are.
- crazycliffy
(3,104 Views)
Yes, I'll mention that this change in behavior is more specifically between 8.0 and 8.20.  I'll post here when I have more info.
(3,084 Views)
This was reported to R&D (446HO4U4) for further investigation.  Thanks for the feedback!
Brian B
Account Manager
(3,066 Views)
