I have read in a NI article (see attach file) that it is possible to import a LabVIEW DLL in Visual Studio.net. I have build a simple DLL (an numeric addition VI) and when i try to import the DLL using the two method(the first two method of the article):
(1) Add a reference to a type library using Visual Studio.net.
(2)Using TlbImp.exe to convert the DLL to a .net assembly DLL.
i always got the message (see error message in attach file)my DLL is not a valid type library or is not a valid COM object.
What is the problem? How Can i do this with LabVIEW 7.0 and TlbImp.exe SDK utility?
When building my dll, i have try different option "standard conventi
on ; C calling convention ; with and with no front panel etc..." i always got the same message.
Thank you for your answers.
derek
