Can not install JSONtext with LabVIEW 2019
When installing JSONtext adds-on by VI Package Manager, I got the below error as shown in the pic and the installation stopped.
Tried running as administrator, even tried to install earily versions of JSONtext, same error.
I'm using LabVIEW 2019 (32-bit) on Windows 10 Home Edition (64-bit based on x64 processors).
(6,038 Views)
Can you install other VIPM packages?  Try SQLite Library, as that package was built on the same computer as JSONtext.
Does anyone else have this issue?
(5,944 Views)
SQLite Library installed.
And I randomly tried another package, QControl Toolkit. Got some downloading issues however not compatibitly error as JSONtext.
(5,912 Views)
The installation of SQLite Library was successful as show above.
(5,882 Views)
I have run into similar issue while installing JSONText package.
Here is a snapshot of the error:
Main Package Name: JSONtext v1.3.1.84
Package Name with Error: JSONtext v1.3.1.84
Error Message: VIPM could not install the package jdp_science_jsontext-1.3.1.84 .
Error Code: 8
Error Source: Write Palette.vi<APPEND>
Complete call chain:
Write Palette.vi
PostInstall.vi
OS: Win10
LV: 2019 (64 bit version)
(5,423 Views)
Code 8 is a file permission error.  Can you try restarting VIPM as "Run as Administrator" and try again?
(5,368 Views)
