Can not publish the contains of the activeX container to the web.
It is easy to publish the front panel to the webserver. But in my application everything on the front panel appears on the web page but the contains of the activeX container (it is images from a web camera!). Does any one knows how to solve this? Is there any restriction on what objects on front panel can be publish to the web server?
(3,195 Views)
I know that you can publish the contents of an activeX container. I have done it several times. It is probably something to do with the activeX control you have placed in it. For instance, it might be that the image from the web camera is updating when the snap of the front panel is taken so that the image of the container seems blank. It also might have something to do with the picture depth you are using. Try playing around with some of the publishing settings you have available such as monitor, snap, refresh rate, picture depth, etc and see if any of them have any effect.
(3,195 Views)
A VI published with ActiveX controls may not have the desired behavior.
Here is a related article:
(2,776 Views)
