Can not run exe appplication on LV 8.5, 64 bit PC with XP windows
Hello ,
I have LV 8.5 , i created exe file from application builder , and installer suitable for windows XP , i have here 2 pc platforms one for 64 bit(HW + XP windows) ,
And another for 32 bit(HW + XP windows)) , the 32 bit  run perfect , but on  the 64 bit causing some issues ,
It seem that  application start to run but after that when starting to communicate with the RS232 it seem to be stuck.
Therefor i assume i missed something for the 64 bit configuration.
Is there special configuration for the 64 bit ?
Did i missed something?
DoronSmiley Sad
(2,813 Views)
Hello ,
I finally managed to fix it , i created new installer and it is working.
So basicaelly  i  can use  the 64 bit Windows xp with the new installer .
Doran
(2,782 Views)
