Can not run my NI-cDAQ 9191 on windows 8.1 pro while it was working fine on windows 7 - can you help me?
I am having  Windows 8.1 pro - 64 bit with 8GB Ram on Laptop.
I am connecting my NI-cDAQ 9191 to the Laptop via ethernet cable.
I am running MAX. It appears  under network devices.
Once I click on it the ip adddress disappear from the system setting screen.
When I click on Network setting  : Network Adapters shows: No Network Adapter found!!!!
is there any solution to this problem
I turned off my firewall.
Waiting for your reply .
Thanks.
Ihab El-Sayed
(2,691 Views)
You should post this issue in the Multifunction DAQ Forum as this has nothing to do with LabVIEW.
Discussion Forum:
http://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
(2,641 Views)
Thanks.
I was wondering , whether this is the right place.
(2,611 Views)
