Can not see the device net Master Interface in my project.
Can not see the device net Master Interface in my existing project. Need to Modify exististing code. Can not recomiple and create exe file after making changes. Error says the vi's are broken. Tried re-installing industrial communications for device net but get an error saying a newer version is already installed. Do I need to plug my computer into the device net scanner to fix this?
Message 1 of 1
(2,536 Views)
