Can not send command via VISA test panel in MAX
Hello all,
I am having a small issue using the VISA test panel in MAX.  I am trying to send a simple command to a device and then retrieve the response data.  I am able to do this successfully via Labview, but for whatever reason I can not get a good response in MAX.  The command that I am sending is simply a letter (address of the device) followed by an end of line character (\r\n in ascii).  In MAX, I simply append the \r\n onto the string sent in the buffer (Send End on Writes == FALSE).  All serial settings are the same as what I have in LV (19.2, 8-n-1).  Does anyone have any thoughts?  This is kind of frustrating as I just want to do something simple and don't want to have to build a whole routine in LV to do this.
Cheers, Matt
(3,837 Views)
I can't get an error unless I read the buffer dry. What error are you getting? Timeout? Clear the buffer and hit the other Clear button, then hit Write then Read. That doesn't work?
Richard
(3,826 Views)
Thanks, Broken.  I am getting a time out error.  Clearing the buffers doesn't seem to be making a difference. This is baffling to me.  I must be missing something fundamental.
Something that I didn't add before is that I seem to be able to send the command via labview without a read, and then read it via MAX.  This must have something to do with way it is sending the command.  Arrrrgh!
Matt
(3,818 Views)
Have you tried using a loopback? That would rule out any idiosyncrasies between your gear and the timing/protocol differences between your LabVIEW ap and MAX.
Richard
(3,811 Views)
Accepted by topic author cirrusio
Whoops!  User malfunction.  I was so positive that I was sending an end of line constant that I didn't look closely at my own code.  Turned out, it was a new line!  Duh!  Thanks for trying to assist with this Arrow.  Sorry to waste your time.
Cheers, Matt
(3,800 Views)
